BobNB
Small font in startup dialog
In my installer, the font in the "Gathering Information" dialog that appears briefly before anything else is very small.
I have don several AI projects and not seen this before, and cannot see where the font size for this dialog is set.
Can you tell me how to fix the please?
Bob
Re: Small font in startup dialog
Hi Bob,
Please note that this is a Windows Installer dialog, therefore you cannot change its settings. This behavior might be caused by the screen resolution you are using. Please make sure that is the recommended one for your display.
Also can you please test the package on another machine to see if the behavior can be reproduced?
BobNB
The screen resolution is correct for the LCD panel. Screen Font Size is normal. This is the only time I have seen this happen. My other two AI installer projects do not exhibit this behaviour. It appears only in this one dialog.
BobNB
I've found the problem...
On the Media - MSI page, setting the Database Code Page to UTF-8 codepage seems to cause the problem. Switching back top Build language specific codepage and the problem goes away, back to UTF8 and it's back again.
Bob
Cosmin
Hi Bob,
Indeed, when using an UTF-8 codepage the characters may be displayed incorrectly during silent installs or uninstalls. Please note that this is mentioned in the Msi Media Tab article.
Cosmin
BobNB
Cheers, thanks for the info.
Bob
