jrahma
create event log source during installation
I have the following problem in my C# application when I try to first run it.. is it possible to create the event source during the installation using Advanced Installer?
http://social.msdn.microsoft.com/Forums ... e2185346e/
GabrielBarbu
Re: create event log source during installation
You can use the Launch File or Open URL custom action to create a new event log source:
eventcreate /ID 1 /L APPLICATION /T INFORMATION /SO MYEVENTSOURCE /D "My first log"
This would create an event source under the APPLICATION event log, of type INFORMATION and with the name MYEVENTSOURCE. For information on how to use the eventcreate utility you can check the microsoft's technet page on Eventcreate
Please note that the custom action needs to be set as "Deferred with no impersonation", since it needs administrator privileges to create the event source.
Gabriel
Gabriel Barbu
Advanced Installer Team
angus_oliver
For your example, can you please clarify how to configure the 'launch file' properties..
I am at the stage of what the attachment shows!
The UI of the "Launch file" custom action has changed a bit since that solution was written on this thread. So, in order to have this working you can configure your custom action as in the example below:
  • File to launch: eventcreate
    Command line: /ID 1 /L APPLICATION /T INFORMATION /SO MYEVENTSOURCE /D "My first log"
    Uncheck the "Run as Administrator" option
Just let us know if you encounter any problem.
angus_oliver
Works like a charm. Thanks very much.
cristian.bejenariu
Is there any way of debugging this Launch File option? I'm having this problem and I don't know what the problem is.
Thanks.
Screen Shot 2018-07-20 at 15.19.28.png (232.07 KiB) Viewed 16406 times
Hi and welcome to our forums.
In order to get more details about an installation failure you can create a verbose log using the "/L*V <path_to_log>" command line.
Return to “Feature Requests”
