slonial
Regarding Removal of files
We are using Adanced installer 3.1.1, we are deploying some of the files
through Advanced Installer workspace.after generation of exe through workspace this exe is deploying the files correctly on client m\c
But what I am finding is that on some m\c on uninstallation, these files are not getting removed.We are not writing any custom action for removing these files as these files are getting added through Advanced Installer(not through Custom Action) so it should remove also.
Thanx,
Sumit Lonial
Ionut
Please see the following forum threads for possible solutions to your problem:
http://www.advancedinstaller.com/forums ... .php?t=961
http://www.advancedinstaller.com/forums ... .php?t=708
I would also recommend that you upgrade to the latest version of Advanced Installer, because several useful features and bug-fixes are available.
Denis
Denis Toma
Advanced Installer Team
