I would like to simplify the installation of my web application with the following steps.
New Installation
1. Define the Web Application folder, which will be created as Virtual Directory
2. Configure web.config settings. Example : connection string, application settings
3. Install web application
3. Execute SQL scripts based on the connection string setting
4. Register COM dll
Update/Patch
1. Auto selects the installed virtual directory
2. Prompt user to stop if IIS services is running
3. Retrieve current web.config setting and display for edit
4. Install web application
5. Execute SQL scripts based on the connection string setting
6. Unregister the old COM dll and register the latest COM dll
7. Restart IIS services if it was stopped previously
Are these proposed steps achievable?
Thanks in advance.
