I am looking create setup project that will ask the user for the name of the virtual directory, create a virtual directory with that name and install my app in that folder.
The question I have is this:
If that folder already exists, I want the installer to find and copy a few files that are located in sub-folders within the parent folder to an alternate location and the copy them back after setup is complete. Is there a simple way to do this?
Another question is, how can I detect the version of MS SQL Server that is running. SQL server will not be installed on the machine that the setup will be executed on. We will be executing some SQL scripts using the SQL Scripts function, but before executing, we need to find out if SQL Server 2005 or 2008 is installed. If an older version is installed, the setup should inform that user and halt.
Any help will be greatly appreciated.
Thanks.
