ericlevin
Per-user file association
It is possible to create per-user file associations for Vista / 7, so the installer can be run without admin privileges.
Eric
GabrielBarbu
Re: Per-user file association
Hi Eric,
You can set your package type to per-user from the install parameters page. The extensions will then be per user. Just make sure all files are installed in per-user location, like in the "Application Data" folder.
Gabriel
Gabriel Barbu
Advanced Installer Team
ericlevin
Thanks for you response.
This doesn't work as the installer tries to write to a protected registry key for the file association. The error message is:
"Cannot write to:
\SOFTWARE\Digitope\AudioEditor\Capabilites\FileAssociations"
I think I need to change the file association capabilities path in Advanced Installer, which is SOFTWARE, but I don't know the right key.
GabrielBarbu
Please send your .aip project file to support at advancedinstaller dot com so we can investigate.
Gabriel
Gabriel Barbu
