Our installer creates a new Windows user via a VBScript. This is a background user for our database server and therefore needs to be hidden from the Windows Logon screen. We're trying to create the appropriate registry entry for this, but try as we might, we cannot get this entry to create through Advanced Installer. We've tried the built-in registry manipulation feature, script regedit, using a registry object in a VBScript, etc. Nothing will add the key to the registry. Script that run fine outside the msi work, but they fail when run from within the MSI.
We're trying to create a DWORD in:
HEKY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\SpecialAccounts\UserList
Any ideas? I'd love to use the built-in registry manipulation features in Advanced Installer as I assume they create the recommended MSI entries to adjust the registry. However a script-based solution would be fine.
Thanks!
Alex
