I don't understand the documentation, starting with this "This type of prerequisites have attached a feature with the same display name. Dependencies between prerequisites or/and application features can be configured using the prerequisite feature.?"
I have prereq for a GUI interface but not for command line installation. So I need to attach the Dot Net Framework to the GUI optional feature. I have called the GUI the "MainFeature" and the command line install just "CMD". When I specify the Dot Net Framework as feature based, it adds it as a separate feature in the Organization Panel. From the above, does this mean that I need to rename that Feature so that is is also called "MainFeature?" What is mean by "attaching" it?
It seemed logical to me that I should drag the Dot Net Framework "feature" to be a child of the "MainFeature" but this is not clear.
I am currently on version 7.7. Is this more clear if I upgrade to the latest (currently 8.0.2)?
