Pete Furness
MDAC Version
How would I test for the (already) installed MDAC version during an install and terminate with a message if (say) it was less than 2.5?
amalia
Hi Pete,
For now your single option is to make a custom action in which you should check the MDAC version. In the future, we intend to add features to help you solving your problem much easier.
Pete Furness
Yes but HOW do I do that?
I need to check for the registry key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\DataAccess
and check the value of FullInstallVer (i.e. FullInstallVer >= "2.50.000")
Can this be done inside AvancedInstaller or do I have create an external file?
Pete
amalia
Hi Pete,
You have to create an external file and schedule it as a custom action. For now you can not check registry values inside Advanced Installer.
Amalia
Harish
Even I need to check the MDAC Version and install it if it is less than 2.5 and install the latest before installing my application. Can any one help?
Thanks in Advance,
Harish.Y
Ionut
You have to add MDAC as a Prerequisite for your install package. In the Prerequisites tab from the Media page, select New. Then:
1. Set the Search Type Criteria to "Registry Value" and in the Registry Value field enter "HKLM\SOFTWARE\Microsoft\DataAccess\FullInstallVer" (without quotes).
2. In the Minimum Version field enter 2.50
Denis
Denis Toma
Advanced Installer Team
Harish
Thank you very much
