Charley
Multiple installation paths
Hello, I'm new to Advanced Installer and I've looked around the program but didn't find how to set multiple installation paths.
If per example my main folder i wish to install is name MAIN and in MAIN i have 3 subfolders called SUB1 SUB2 SUB3.
I want to install SUB1 in C:/SUB1/, SUB2 in C:/yeah/SUB2 and SUB3 in C:/Holla/back/SUB3.
Is there a way to achieve that?
gigi
In the "Files and Folders" page the "Windows Volume" folder is the root path where the os is installed usually "C:\". Create under this folder your sub folders by choosing "New Folder->Regular".
If the os is not installed on "C:\" then create a property under the "Install Parameters" page and create a "Property Based" folder with it like this:
MYFOLDER   C:\
Gigi
________________
Gheorghe Rada
Advanced Installer Team
Return to “Feature Requests”
