teplo
Find and store folder path containing a file
Hi, I use search for a specific file on all drives.
The property return full path with file name (like c:\test\myfile.txt), but I need only the path (c:\test\). How can I do that ?
Cheers.
teplo
Sorry bad topic
Oups I think I have not posted my question on good forum topic !
gigi
The "File Search" returns is the full path including the file name. To remove the file name from the path you need to create a VBS custom action and schedule it after "InstallExecuteSequence->AppSearch" standard action.
Or if you want to search for a folder create "New Search", "Add Location->Folder" in the "Search" page.
Kind Regards,
Gigi
______________
Gheorghe Rada
Advanced Installer Team
teplo
Ok I will try it, It's better to create a inline script or external script ?
gigi
Please see this for more details about all custom actions type supported by Advanced Installer:
http://www.advancedinstaller.com/user-g ... types.html
Gigi
______________
Gheorghe Rada
Return to “Feature Requests”
