nvsoft
Creating mandatory updates
I'd like to include the AI updater agent with my application and use it to check/install updates during app start up.
However, I could not find a way to show the user the updates and their description and then force installation of certain updates.
My desired scenario is as follows:
1) The main application calls updater to check for updates.
2) in case new updates exist, the application closes and and a dialog is shown to the user with a list of available updates but do not allow the user to uncheck them (check and disable their checkboxes).
3) the user presses "next", the updates are installed and the application is started again.
I'm aware of the /silentcritical command switch but it doesn't suite my needs as I'd like to show the user a list of available updates.
How can I achieve my desired scenario?
Thanks.
mihai.petcu
Re: Creating mandatory updates
To achieve this you can follow our user guide article.
You can use the /silentall option to achieve this. For more information you can follow this article from our user guide.
You can configure this from your updates configuration project -> Updates Page -> your update -> Auto Close Applications tab. Here is its reference in our user guide.
nvsoft
As I said in my original post, I would like to show the user a dialog displaying all of the updates about to be installed (and their descriptions).
Will the /silentall option show this dialog to the user?
I can display this dialog to the user myself and then call updater with /silentall but I could not find an interface or API to get information about the available updates.
Once again: I would like to make certain updates mandatory and not allow the user to uncheck these updates.
Thanks.
Yes, you will see our predefined dialog, but the update will start download and install automatically, without requiring user actions.
If you want to display your own custom dialog you can use the switch "/justcheck" and get the return code from the updater to see if updates are available or not. Then based on the returned code you can proceed as you wish.
