vakbijevs
Can not uninstall application if it's running at the moment
I would guess, it should be able to check it's running and close it. Or to display an apropriate error. At the moment, if trying to install the aplication while it's running, it will give error that should quit "Lotus Notes" before continuing and would not let you go any further. If you actually quit "LotusNotes" and click retry than it fails with strange error and application stays running.
gigi
If your application is running on uninstall then windows installer pups up with "FilesInUse" dialog asking you to close that application. This is the normal behavior.
Please make sure that your application is closing correctly, after you close it verify if the associated process is closed, maybe it hangs on something. You can verify that with a process explorer.
Best Regards,
Gigi
_______________
Gheorghe Rada
Advanced Installer Team
vakbijevs
gigi wrote: If your application is running on uninstall then windows installer pups up with "FilesInUse" dialog asking you to close that application. This is the normal behavior.
:roll:
Q1: Dialog ask to close Lotus Notes only if our appilcation (Java based) is running. Are you sure that it is normal behavior?
Q2: How I can check running application (i don't ask about Lotus Notes) and close it before uninstall? An VBScripts?
gigi
If one of the files from your application is in use (by any program) at the time of uninstall then the "FileInUse" dialog will appear asking you to close that application first. This is controlled by Windows Installer and is a normal behaviour.
A custom action can be done, but there is no guaranties that any application can be closed correctly (by sending a WM_CLOSE message to it's main window). For example an application can have a confirmation dialog on the close button.
Best Regards,
Gigi
______________
Gheorghe Rada
vakbijevs
[/quote]
We don't have an confirmation dialog. So, can you provide an solution (script) to close application before install/uninstall?
