tommobb
Prerequisites and Vista 64 Bit
We have a pre-requitsite that checks a registry key exists for a Visual C++ redistributable. When running on Vista 64 bit we get the 4154. On other OS'es it works correctly (XP, 7 and Vista 32 bit)
We have written some C++ code which detects the key properly
DWORD res=RegOpenKeyExA(HKEY_CLASSES_ROOT,("Installer\\Products\\6E58EC68CABDDFF39B774E7BF9389C90"),0,KEY_QUERY_VALUE|KEY_WOW64_64KEY,&hKey);
Is it possible the installer is not detecting this key?
Re: Prerequisites and Vista 64 Bit
This could happen because of OS redirection system for 32 bit applications on 64 bit machines. A solution is to create a new prerequisite marked as 64-bit
from Properties tab. Also, from Install Conditions tab you should set both prerequisites to be detected only for 32 and 64 bit systems, from the Launch Conditions group.
Return to “Feature Requests”
