pachwald
auto-repair does not work
Hi there!
After installation of my program I tried to test the auto-repair functionality by removing a dll from the application directory. Starting the application does not lead to a auto repair action. Instead the application fails. Do I have to configure the files or components in any special way to enable windows installer auto-repair?
Alex
gigi
Hi Alex,
An auto repair starts if a key path for a component is missing. Are you sure that the DLL you have deleted is key path in its component? Can you reproduce this on other computers?
Best Regards,
Gigi
______________
Gheorghe Rada
Advanced Installer Team
pachwald
Hi gigi!
The component for my dll only contains one file and it has the key symbol in front of it's name. Properties are:
GUID: {F59318AD-624D-4DFC-B3DA-4CDE7D6C8686}
Directory: APPDIR
no condition, no attributes, no additional space, no qualified components Groups, no components isolated with this component.
I checked this on several testers' machines and the same happens there.
Any suggestions?
Alex
gigi
Hi Alex,
Note that an auto repair it's triggered if a key path for a component is missing. Windows Installer verify this when an advertised shortcuts, file associations, etc is executed. Non-advertised shortcuts don't trigger an auto repair.
For example try to open your application from a file association. You will see that Windows installer triggers the auto repair.
Best Regards,
Gigi
_______________
Gheorghe Rada
