qwerty1980
Removing this banner?
Can i remove this banner?
Can i remove the marked thing?
Re: Removing this banner?
The theme used for your project is HTML based, this means you will need to edit our sources, from the install folder of Advanced Installer on your machine.
Please note that editing these files will affect all projects you build from now on, so I recommend first trying this on a separate machine.
You can find all of our sources for themes UI in the main installation folder of Advanced Installer, sub-folder "themes".
qwerty1980
Thanks Bogdan :D
I will make a backup copy of it and then edit :)
EDIT: So i navigated to ...\Caphyon\Advanced Installer 8.2\themes\spring\resources
I saw HTML files in that folder. Now which HTML file should i open and how can i remove the banner?
mihai.petcu
Can you please specify the theme you are using?
If it's Azure, then you can remove the logo by editing and replacing the background images from the Themes page -> Images tab.
Jeak
And what's with the theme "Spring"?
Would be really nice to get a short instruction.
mihai.petcu
The Spring theme uses Enhanced UI and is based on HTML.
Here are a couple of related articles to help you understand how it can be customized:
http://www.advancedinstaller.com/user-g ... theme.html
