meetshashank
AI Queries with Validation/MSI FILE
Hi All-
We are using latest version of AI.
I have following Queries for the same
1) How i can do validation on text box in wizard. If Textbox having properties like below,
SERVER_PROP
DATABASE_PROP
USERNAME_PROP
PASSWORD_PROP
If any one of above text box does not have values NextButton should be disabled for wizard.
Screen shot is attached here.
2) When i Build Installer it creates two Files under \\SetupFiles folder.... One is Application and other is Windows Installer Package.
I want to create only one file i.e Windows Installer Package. How i can achieve that.
3) I am using Spring Themes
How I can remove the Modify and repair button.
How I can remove the custom installation option.
It’s very urgent, please suggest.
Thanks in advance
Many Thanks
Shashank
Validation For Text Box
Re: AI Queries with Validation/MSI FILE
Hi Shashank,
1) For this you have the "Control Conditions" tab. Just select the "Next" button and then add "Enable" and "Disable" actions, using as conditions for them the properties of the edit boxes.
2) In order to enable this option you need to go to Media page, Bootstrapper tab and select "Include install files in EXE".
3) This theme is HTML based, for editing its dialogs is need to edit the HTML source code of the hosts loaded on those dialogs. The following tutorial contains more details.
Return to “Feature Requests”
