meetshashank
Need Help on Formatting Text on Spring theme dialog
Hi -
We are using spring theme dialog for setup. Need to modify Welcome Dialog box and other. Like Attach 1Test attachement We want to remove Welcome Word as well as Advance Installer from each page.
We saw [WelcomeDlgSubTitle] used in HTML page. Where we can set the property value? (We want to Change it) . FYI we are using Include Install File Exe.
Also we need to do validation on Next button of the SQLDatabase dialog box.(2_Test.JPG) Image attached here
Like want to disable the button if Server name/Database name/UID/PWD not entered.
Also want to remove Custom Button from Last Screen. Like (Repair,Modify etc)
Please suggest.Thanks in advance.
Many Thanks
SPK
Re: Need Help on Formatting Text on Spring theme dialog
Please note that "Spring" is an HTML based theme, so for editing its dialog's UI you actually need to edit its HTML sources. Here are some tutorials written by us on this subject that can help you:
http://www.advancedinstaller.com/user-g ... theme.html
Return to “Feature Requests”
