Jan Bouma
copying folders and files
I have two aip's
In the first i had some folders en files which where installed.
In the second i needed the same set of folders and files. So i copied them from aip 1 to aip 2.
this went all fine.
But when i run aip 2, the folders and files are not installed.
Why is this ?
mihai.petcu
Re: copying folders and files
Hi Jan,
This could happen if the resources' components have the same GUID in the Organization page. However, the context menu copy-paste operation used from one project to the other generates new GUIDs for the components.
Can you please send us both .AIPs and the failing installation's verbose log so we can see the reason why this is happening?
