mcisy
Install MSIs with one MSI
Hi there,
First of all, I'm an absolute MSI beginner, so thanks in advance for your patience.
What I'd like to do is, to install 4 msi packages (Office Interactive handbooks) with one big MSI package.
I read a lot, and thought "prerequisites" might be the best way. And it works. All 4 Handbooks were installed. But at the end of the installation, my big MSI package displays, "Warning 4154 Word Prerequisite was not correctly installed" even if it was.
What I did was:
I added a "NEW..." Product "WordHandbook.msi"
And added "Command line for each UI level" "/qn" for all three options.
Why does my big MSI think that something went wrong during the installation?
Thanks for reading this
Isy
Re: Install MSIs with one MSI
Hi Isy,
In the following article we explain why this warning message appears.
http://www.advancedinstaller.com/user-g ... question60
However, you should now that prerequisites requires as output an EXE setup package, with the MSI files included in it. If you want only an MSI
you could also use chained packages.
http://www.advancedinstaller.com/user-g ... ckage.html
mcisy
Hi Bogdan,
Thanks for your quick response!
I'll try to solve it with a chained package.
Best wishes from Germany!
Isy
mcisy
Hi Bogdan,
Chained Packages are working well for me! perfect!
One more question: I have to enter a "Package Path"
Can I enter relative paths, like .\word.msi? Or integrate the word.msi and excel.msi files in my big MSI package?
Isy
Hi Isy,
I'm afraid for this you cannot use relative path, you must specify the full path for the package that will be included in the main setup.
I'm afraid I don't understand, by adding them as chained package they will be automatically included in the main, i.e. "big", MSI package.
mcisy
Hi Bogdan,
okay all chained msi packages will automatically be included in the main.I thougt the "Package Path..." must be the same path on the destionation PC where my master.msi will be installed.
I'm fine thanks!
No, this represents the source path of the chained package that will be included in your main MSI package.
Return to “Feature Requests”
