anupmistry
Prerequisites wizard disable Finish
Below is the screen that appears for the Pre-requisites wizard welcome screen. It says clicking 'Finish' bypasses pre-req install. Users who are not reading the on-screen instructions may just assume that everything installed. Anyway to customize this screen? Would like to force user to click on 'Next' so pre-reqs wizard always runs if it detects they are absent.
mihai.petcu
Re: Prerequisites wizard disable Finish
If you disable the "Continue with main installation even if the prerequisite is not installed" option from "Prerequisite Properties Tab", the Finish button will be automatically disabled.
Clicking "Finish" does not cancel the installation, only the pre-install prerequisites installation.
The pre-install prerequisites UI customization is limited, but can be changed from "Bootstrapper UI" in the Dialogs page Install Sequence pane.
