Marek
Problems with Updates Configuration in AI 9.1
Problem 1.
The reported problem concerns the Update Descriptions Tab.
There are four edit fields: Description, Feature, ect.
I have polish Windows 7 with installed keyboard type: Polish (programmer).
If I click combination right Atl+a, then I always get a Polish character 'ą'.
But in AI 9.1 all content of edit field is cleared before inserting Polish character 'ą'.
In case other Polish characters (like ęśżźćńół) problem don't exists.
Problem 2.
If I use Polish characters in my update project, there is a problem with displaying Polish characters in the window "Choose Update to Install".
mihai.petcu
Re: Problems with Updates Configuration in AI 9.1
Thank you for reporting this, we'll look into it. Meanwhile, this shouldn't be a show stopper as there are other ways to insert that character.
Do you have those strings localized? Please keep in mind the description for each item is specified on a single row of the field.
Also, can you please give us more details? Perhaps post screen shots to evidentiate the problem.
Marek
This is the contents of the update file.
;aiu;
[Update_2.0.0]
Name=TRX Radio over IP 2.0
ProductVersion=2.0.0.0
URL=http://www.trx.com.pl/dl/inst/RoIP/TRX_RoIP_2.0.exe
Size=10776920
ReleaseDate=04/05/2012
MD5=248e793dae70eaf2e33fd25aa1b634ba
ServerFileName=TRX_RoIP_2.0.exe
Flags=NoCache
RegistryKey=HKUD\Software\TRX\TRX Radio over IP\InstallVersion
Version=2.0.0.0
Description=TRX Radio Over IP 2.0
Feature=Obsługa Motorola GM 360
Feature1=Obsługa Motorola GM 380
Feature2=Obsługa Kenwood NX-700
Enhancement=Poprawa wyglądu programu w stosunku do wersji 1.x
Enhancement1=Poprawa szybkości działania
The generated result is shown in the image in the attachment.
mihai.petcu wrote:Do you have those strings localized?
How can I localized those strings?
Bug example. Instead of Polish characters are squares.
mihai.petcu
Here are a couple of threads to help you localize the update configuration file in polish:
Using a dictionary is an auto updater?
How to localize and specify language for the Updater project
Marek
It is not working. I have same file what I created manually. Effect is the same as I wrote in Mon May 07, 2012 8:46 am.
mihai.petcu
You should have a separate polish updates configuration file. The first reply from the first link I posted describes the process.
Can you please specify the steps you performed so we can find out why it's not working?
Marek
Mihai, to be clear. I'm talking mostly about the correct display of Polish letters in sections Description, Features, Enhancements, Bug Fixes. The rest may yet remain in English.
No matter whether I used the dictionary, or I do it manually the update file is always correct. It contains Polish letters where it should be. The problem is in their display in window generated by updater.exe.
If you want I can send you my AIP and AIL files.
mihai.petcu
Yes, please do. Send them to support at advancedinstaller dot com so we can investigate.
mihai.petcu
We have tested this and unfortunately are unable to replicate the behavior. We built update configuration projects in both English and Polish and the result shown all the polish characters correctly:
There was a bug however when adding a custom dictionary for untranslated strings. This produced an updates configuration file with * occurrences instead of the localized text itself. We will investigate and fix this in a future version.
This has been fixed in version 16.8 of Advanced Installer, released on February 18th, 2020.
