Jimmy
/SetVersion as a PreBuild Event
Hi there
I was able to get a new Package Version using /SetVersion -fromfile- method with commandline tool.
I it possible to something similar as a pre-build event?
I assume it doesn't make some sense if I try to implement the CL- method to a project, while it is open?
Thanks in advance an d best regards!
Jimmy
mihai.petcu
Re: /SetVersion as a PreBuild Event
Hi Jimmy,
Unfortunately, you cannot perform any Advanced Installer CLI changes on your project as a build event. This happens because that information is used from memory at build time and not from the disk.
You can try a designated automated build CLI approach like ANT for example.
Jimmy
Hi Mihai
Thank you for your answer, which saves me a couple of hours to try needless tests!
Great support!
