rbfen
SQL Script Conditions - Software version
Is it possible to have a condition on a SQL script that will allow the script only to run on a certain previous version?
Example: My software is currently version 2.1.3
I want a certain SQL script only to run if someone is upgrading from software version 2.0.0
Is this possible and if so, how can it be done?
mihai.petcu
Re: SQL Script Conditions - Software version
Here's the "Best practices SQL change scripts?" thread you can follow regarding this.
rbfen
Hi Mihai, thanks for the reply. I had found that particular post but could not get it working, perhaps I am doing something wrong though.
I have this, in my SQL Script condition:
OLDPRODUCTS >< VER_2_0_PRODUCT_CODE
When I run the installer version 2.1.3 on a system with 2.1.1, the SQL script is still running.
mihai.petcu
Maybe you have the wrong product code stored in VER_2_0_PRODUCT_CODE property. You can keep track of the properties values with MsgBox occurrences. Better yet from the verbose log of the installation.
rbfen
Thanks Mihai, that was it, got the correct code from the logs per your suggestion.
