Turelim
Configuring a Database only if a requisite is installed
Hi guys, this is my first post in the forum. and my first time creating an installer with Advanced Installer 9.3, so this is my question...
i want to configure a database only if a prerequisite didn't install because the user has already installed previously; some ideas :? ??
Re: Configuring a Database only if a requisite is installed
Hi and welcome to our forums,
This is very easy, every SQL scripts that you configure to run can use a property as an execution condition. So what you need to do is to create a search in Search page, identical with the one that tells if your prerequisite is installed or not. The search name is actually a property, so you can use it in the condition field from SQL Scripts page, on your configuration script.
Turelim
ok, let me check it :D
