v.rooijen
Show only if
I have two features and three dialogs
client feature
server feature
browse iis dialog (for client feature)
sql connection dialog (for server feature)
logon information dialog (for server feature)
As you can imagine, I want to show the iis dialog when the user selects the client feature
And I want to show the sql and logon dialogs when the user selects the server feature
This is achievable by using the "Show only if" option on the dialog and select feature is installed (&Feature = 3)
What I can't get working is:
When the user selects both the client and server feature, all three dialogs should be shown.
The Show only if condition should be correct, because the feature is installed and will return true, however, after the first dialog, the user returns to the VerifyReadyDlg
v.rooijen
Re: Show only if
Ok, I have found the solution at
http://www.advancedinstaller.com/forums ... =2&t=20149
However as mentioned it's just a little cumbersome if you have multiple features and dialogs, maybe a nice feature request? :)
Re: Show only if
Please keep in mind that a "Show only if..." subchain allow you to select what dialogs will be displayed and also, in what order it will be displayed when a condition is true.
If you have any question or suggestion about this let us know.
