antidotcb
Multiple feature based chained packages
I have following functionality to implement:
Amount of similar minor .msi files that will be developed by me using AI (some file deployment, some configuration changes)
All above msi-packages are about to be installed in one major package
I am trying to implement them as feature based prerequisites.
- I need to do some custom actions before installation of these minor packages *OK*
- I need to install these minor packages one by one, in case of failure of any - should allow to user to interrupt or continue overall installation process *OK*
- I need to choose which of these packages will be installed *OK*
- I need major package do some custom actions for overall configuration after installation *OK*
- I need to uninstall all these minor packages with uninstallation of major *FAIL*
- I need these minor packages installed when I run major package installation in silent mode *FAIL*
I was thinking that following fields control this behavior (see screenshot), but in reality these fields do nothing and result the same:
- if I run installation in silent mode - no chained packages are installed
- if I uninstall major package - no chained packages are uninstalled
Re: Multiple feature based chained packages
Please keep in mind that on Windows Vista and above, in order to silently install prerequisites packages the main installation package should run elevated. So, you should check "Run as administrator" option from "Install Parameters" page, or use the "Run as administrator" context menu option from Windows Explorer when installing.
I've tested your scenario using version 9.3 of Advanced Installer, but I cannot reproduce the behavior. Can you please give us more details about this (maybe exemplify)? Also, can you reproduce this on multiple clean machines?
