jmace
When to execute registry backup
I have my application set up where it writes to the registry a number of keys. When I run an auto or manual install my registry keys get wiped out even when they are set to not get deleted on uninstall. I have a script that backs up the registry from this post: http://www.advancedinstaller.com/user-g ... eg-ca.html but am not finding the right execution point for it.
Any ideas,
Jim
Re: When to execute registry backup
Hello Jim,
In order to achieve what you want you can proceed like this:
- Go to "Install Parameters" page and enable "Run as administrator" option.
- Go to "custom Action" page and add the related registry backup script custom action under "Install Execution Stage" -> "Paths Resolution" action group.
- Add the restore and delete registry backup script custom actions after "Finish Dialogs Stage".
- Build and run your project.
Also, starting with version 9.4 of Advanced Installer you can achieve this using our persistence feature. You can proceed like this:
- Go to "Registry" page, select your registries key and from its context menu choose "Properties..." option.
- In the "Edit Registry Key" dialog -> "Operations" tab enable "Preserve key content" option using desired condition.
Let us know if this helps, otherwise give us more details about your scenario.
