MattGreaves
Repackaging .MSP's
Hi all,
Apologies for my inexperience on this topic, so please forgive me..!
Can any one provide me with instructions on how to repackage an existing .msi & .msp together into a new MSI please? The software deployment method we have does not work with .msp so need to find another way of deploying it!
Many thanks,
Matt 8-)
Re: Repackaging .MSP's
Hi Matt and welcome to our forums,
Here is what you can try:
- the MSI import it into a new project using our "Import MSI" support, this will create a new .aip file for you
- now use the Repackager to capture the MSP installation on a clean machine where your original MSI is already installed. This will create a .rpk file, save it.
- in the new .aip file created at step 1 go to "Import Repackage Result File" and select the .rpk file from step 2
After doing all of this you might need to make some adjustments to your project, to make sure no conflicts arise or something else like that.
MattGreaves
Hi Bogdan,
My apologies the existing installer is actually an .exe rather than an .msi so presumably the instructions below are no longer valid?! Obviously I got confused when dealing with several application titles at a time!
Cheers,
Matt
MattGreaves
Ignore that last message (not sure how to delete the post!) I got confused AGAIN! Will give your instructions a try and see what happens. Thank you!
MattGreaves
Worked out another way of doing this so no longer required. For reference I opened the existing .msi within Orca, applied the .msp and then generated a .mst file from that :)
