rrajasankar
suppress the " “Deleting extracted files”
How to suppress the " “Deleting extracted files”, after the installation was complete?
Also, how to configuring the progress bar text as per our project details?
Raja
mihai.petcu
Re: suppress the " “Deleting extracted files”
Hello Raja,
This message is shown by the bootstrapper and unfortunately it cannot be suppressed.
The ActionText static text on the ProgressDlg usually shows the description of the currently running action. On the Custom Actions page, select your custom action and press the "Action Text" button. Please keep in mind that Action Text can only be used with a custom action that runs with Deferred execution option.
rrajasankar
Thanks for your reply. We done the modifications as per your reply..
vlicaros
Sorry to bring up this old thread but I can't seem to find the exact string for "Deleting extracted files" in the dictionaries. The translation for CHT seems to be incorrect and would ilke to change this.
You can change the text from the Table Editor page --> ActionText table:
vlicaros
Thanks for getting back to me about this, I want to change this not just for English but also other localization languages like zh_tw or zh.
This specific dialog is coming up with garbled text after a removal. I have attached the screenshot of the garbled text, which seems to be a bootstrapper UI text that's not similar to the AI_DeleteLzma since they both are almost identical text strings but not quite. AI_DeleteLzma is "Deleting files extracted from archive" and the one in the screenshot is "Deleting extracted files..."
gabled text.png (878.68 KiB) Viewed 7766 times
This dialog is displayed by our EXE support of removing the extracted MSI and CAB file after installation. Our EXE bootstrapper embeds an MSI and a CAB installation files. These embedded installation files are extracted at install time in the location defined in "Builds page -> Configuration tab" -> "Extract location" field. After the installation finishes these files ar being deleted by an asynchronous process launched by our EXE bootstrapper. During the files removal operation a quick message box is displayed ("Deleting extracted files").
I'm afraid this message cannot be customized.
vlicaros
Hi Liviu
Since the text cannot be customized, can it be fixed by AdvancedInstaller with the garbled string in ZH? it starts with a "?" rather than the actual Chinese character
I have forwarded this to our development team and hopefully this will be fixed in a future version of Advanced Installer.
