In order to achieve what you want you can take a look on our
"Browse for folder" article. If you want to browse to "Application Data" folder, then you can use the following property:
in the related field from "3 -> b)" article step.
Also, if you want to obtain the same behavior in "FolderDlg" dialog, then you can set the "Application Folder" field, from "Install Parameters" page, with the following value:
Let us know if this helps, otherwise give us more details about your scenario.
