jwise
create blank directory
How do I create a blank directory below the product installation directory: i.e. installation is in c:\app. How do I create c:\app\blank
abdullayev007
Re: create blank directory
In Files and Folders page, click on the Application Folder, and then right click > new folder > reguler follow this.
In order to create a new folder in "Files and Folders" view you can use the [ New Folder ] toolbar button, the “New Folder” tree/list context menu item or press the "Insert" key while the tree control is focused.
Also, if you want the related directory to be always created on target machine, then from its context menu choose "Properties..." option. Then, in the "Edit Folder" -> "Properties" tab check "Create folder on target machine" option.
thill
Daniel wrote:In order to create a new folder in "Files and Folders" view you can use the [ New Folder ] toolbar button, the “New Folder” tree/list context menu item or press the "Insert" key while the tree control is focused.
With 10.9.1 using a staged directory structure for the appdir source empty folders are NOT created. When using the folder Properties to set "Create folder on target machine" the checkbox does NOT retain the setting after a save, close AI, and restarting AI. When going to back check the setting is always cleared (disabled).
Is there a solution without putting a dummy file in the directory?
Currently this is our default implementation when using the synchronized folder option. However, we will try to add an improvement regarding this in a future version of Advanced Installer. Thank you for your suggestion. Until then, as a workaround you can create the related blank folder on disk under the synchronized root folder.
