mbilet
Localization issues
Hello.
There are a few issues related to localization:
- For some languages, the 'Browse' button is cut in the installer dialog where you select a folder.
- The installer 'Reset' button is not localized.
- The installation 'Browse' dialog is not localized.
- The 'Ok' and 'Cancel' buttons are not localized in the upgrade notification.
- The 'Cancel' button is not localized in the installation 'Emplacement'dialog.
- The 'Browse' dialog's title is not localized in the installer.
- During installation of the Chinese version of the product some English text is shown(e.g. files for removal).
Current version of Ai- 9.2.
mihai.petcu
Re: Localization issues
Can you please help us replicate each problem separately? Here's what we need. You described the problems, now all we need is "How to reproduce ?" and the "Environment" for each issue.
The first issue was debated before and should be solved. Here's the related thread.
mbilet
I'm using AI 9.2
- According to the first issue (For some languages, the 'Browse' button is cut in the installer dialog where you select a folder.) it is still reproducible. Win XP.
- The installer 'Reset' button is not localized (e.g German language). Win XP/7. This button is in 'Feature Selection' dialog that appears after license agreement dialog.
- The installation 'Browse' dialog is not localized (Spanish language). Win XP/7. Dialog for choosing installation folder.
- The 'Cancel' button is not localized in the installer dialog where you select installation folder (e.g French, Chinese, Japanese). Win XP/7.
- The 'Browse' dialog's title is not localized in the installer. Win XP. Word "Open" isn't localized in the dialog for choosing installation folder.
- During installation of the Chinese version of the product some English text is shown (e.g. files for removal). Win XP/7.
Hope this information will be useful.
Mykola
Hello Mykola,
Indeed, this seems to be an Advanced Installer localization issue. A fix will be available in a future version of Advanced Installer, thank you for bringing it to our attention.
Also, I'm afraid that I wasn't able to reproduce the rest of the reported issues. Can you give us a detailed step by step test case scenario for each one of them so we can try to reproduce the behavior?
This was fixed in version 11.1 of Advanced Installer released on April 28th, 2014.
mbilet
Want to highlight that one of the issue:
is still reproducible (also it is valid for French and Italian languages)
I just realized that some translations are skipped for Chinese language in the "Project strings" tab.
Maybe this is the root cause of the issue.
Could you have a look and help me to fix it?
AI 11.7.1
Win 7
Mykola
Hello Mykola,
This is the normal behavior. This happens when you are integrating our "Uninstall Cleanup" feature in your project. Our default dictionary strings don't include an action text localization for all our predefined custom actions. We'll try to update our dictionary files in a future version of Advanced Installer. Thank you for bringing this to our attention.
Until then, as a workaround, you can use our "Project strings" tab to add the missing localized strings and save the changes into a dictionary file.
mbilet
Could you give approximate estimate when dictionary files will be updated?
Mykola
Hello Mykola,
The update will be included in our next version of Advanced Installer which should be released in the forthcoming weeks. We'll update this thread as soon as the next version is out.
Hello Mykola,
The above update has been added in version 11.9 of Advanced Installer released on March 17th, 2015.
ovarsh
Hi Daniel,
I noticed some other not translated strings: "removed files" and "Configuring". Screenshots are below.
Are you going to fix it? Could you please provide preliminary estimate for that?
Oleksandr
Hello Oleksandr,
We'll try to update the Chinese localization for the related strings in a future version of Advanced Installer. Thank you for bringing this to our attention too. However, I'm afraid I cannot give you any ETA for this. We'll update this thread as soon as the update is out.
Until then, as a workaround, you can localize in Chinese the "ActionText.Description.AI_AiRemoveFilesRollback" localization ID from "Translations page -> Project strings tab" and the "UIText.ConfigurePackage" localization ID from "Translations page -> Default strings tab".
ovarsh
Daniel,
thank you for provided information. I will be waiting your notification about fix.
Oleksandr
You're welcome Oleksandr. We'll notify you once they are updated.
Also, if you have any suggested Chinese translation for the related strings don't hesitate to write us an email to support at advancedinstaller dot com.
prashant
Installer doesn't localize progress status message for chained package installation.
