When I put them in their correct places the patch file size was about 80 MB
How big are your target and upgraded packages? 80 MB seems very much for a patch and I still incline you should go with a major upgrade. BTW, a major upgrade gives you less headache than a patch. We don't recommend using patches unless you really need to.
the problem may be was that I was installing from the EXE installer then patch. When I firstly installed from the MSI installer then run the patch it worked correctly, However it still doesn't work on XP and gives the same error that the package may be corrupted.
Please keep in mind that when applied, the patch will request the original MSI package (because, by default, the bootstrapper deletes the extracted files). In order to avoid this problem, select the option "Do not delete extracted MSI and CAB files" in the Media page, "Bootstrapper" tab.
Also the installing error I mentioned before ("Not able to retrieve SourceDir property") is still happening on windows 7 & XP.
Can you please give us the exact error message (maybe attach a screenshot) and send us the project file (.AIP) and a
verbose log to
support at advancedinstaller dot com so we can investigate?
