rrajasankar
Install an application on click Next
I need to install Firebird application. In my application 2 features available(console, server). For server feature, firebird need to install. When i select server feature, then click next button, at that time firebird will install. Is there any option for install an exe application through "Execute Custom Action"? (We tried the Script Inline function for Display message box)
Re: Install an application on click Next
In order to achieve this you can take a look on our "Start exe from button" thread.
Let us know if this helped.
rrajasankar
HI,
Thanks for your reply.
If we install the Firebird application in Wizard Dialog Stage(before the dialog start up), firebird installation was fine. But, we need to install the firebird based on feature selection(Customize Dlg). So, we tried to install the Firebird application in Install Execution Stage, in all machines firebird installation was fine, but only windows 7 machines have some installation error.
We require to install the firebird based on the feature selection(Customize Dlg). If we select the feature 2 , firebird need to install.
How to install the firebird application after the feature selection(Customize Dlg) and before the Install Execution Stage?
Please help us.
Raja
Hello Raja,
In order to achieve what you want you can proceed like this:
- Go to "Files and Folders" page and add your Firebird application file as a temporary file to your project.
- Go to "Custom Actions" page and add a "Launch file or open URL" (i.e. MyApp) custom action without sequence like this:
  • Command: "[&FirebirdAPP]"
- Go to "Dialogs" page, select the "VerifyReadyDlg" dialog and on [Install] button add a published event like this:
  • Name: Execute custom action
    Argument: MyApp
    Condition: &MyFeature2Identifier = 3
rrajasankar
HI Daniel,
We resolved this case with your suggestion. Thanks for your help.
Raja
You're welcome. Glad to help.
