Assassin
So im wanting to create my own licensing form.
I want to use the trial.dll and its features but not use the advanced installer licensing form.
Ive got my own custom form and ive made it write to registry and stuff like that all works fine.
But the issue ive got is there a way to get hold of the request license code from the registration tab
is there anyway i can call this from the .dll function?
So im wanting to on form load have that number displayed on the email within my application form
Im wanting to totally avoid the advanced installer license window and this is the only thing stopping me.
Re: So im wanting to create my own licensing form.
In order to achieve this you can use the "CompId" property. Also, if you want to get the related property value from your own code you can take a look on our "Retrieve Licensing Elements" article.
Assassin
Daniel.Radu wrote:Hello,
<DllImport("Trial.dll", EntryPoint:="GetPropertyValue", CharSet:=CharSet.Unicode)> _
Private Shared Function GetPropertyValue(ByVal aPropName As String, ByVal aResult As StringBuilder, ByRef _
  aResultLen As UInt32) As UInteger
End Function
Dim val As StringBuilder = New StringBuilder
Dim len As UInt32 = CType(val.Capacity, UInt32)
If GetPropertyValue("TrialName", val, len) = 234 Then
  val = New StringBuilder(CType(len, Int32))
textbox.text = CompID
'So i just want the compID to be loaded into this textbox'
End If
So ive tried changing a few new properties but I wouldn't work - So im working in vb.net
- So ill give you the clean version im unsure which properties I actually need to change.
Thanks if you can help me :mrgreen:
In order to achieve what you want you should use the related GetPropertyValue function to get the CompId (and not CompID) property value. For example, in the above code you should replace the "TrialName" parameter with "CompId". Then, you can assign the "val" variable (which will contain the "CompId" property value) to the related textbox.
Assassin
    End Function
        If GetPropertyValue("CompId", val, len) = 234 Then
            TxtCompID.Text = val.ToString
   End If
There is the working code if anyone else has this problem
Thanks For Your Help :mrgreen:
