Nick Hunter
Can't delete a file from "Files and Folders"
I have an install project which builds OK but there is a file in the Application Folder which I want to remove. When I click on the Delete button or hit the Del key it disappears from the list but when I save and then reopen the project it is still there. It also remains in the built MSI file.
I guess it's a bug.
gigi
Hi Nick,
The folder that contains the file is synchronized? If this is the case then the file is re-added to the project on load or build. This is because the content of the synchronized folders is refreshed when build or project load.
http://www.advancedinstaller.com/user-g ... lders.html
Also you can specify filters for synchronized folders:
http://www.advancedinstaller.com/user-g ... ialog.html
Gigi
______________
Gheorghe Rada
Advanced Installer Team
Nick Hunter
Thanks. You were right the folder was synchronized. When I took the synchronized option off it worked fine.
teknohippy
I had the same thing recently although the folder was not synchronised.
I had to set it up for sync, unset it, and then delete it.
