mheckmann
Warning 1910. Could not remove shortcut
it was reported from multiple users that while installing an update of our software they get a:
Warning 1910. Could not Remove Shortcut
Error. When clicking ok, the shortcut is actually removed and the installation continues. Any ideas on what could be triggering this?
Thx
Markus
kerkhofftech
Re: Warning 1910. Could not remove shortcut
Since the upgrade to build 47481 (Advanced Installer 9.6 Professional) we also have this error message popup on uninstall. The uninstall seems to work as expected besides this error msgbox.
NBBob
Same problem here!
Can you please provide a verbose log created on one of the machines that reproduces this problem and also send us an e-mail with .aip file used to build the setup?
NBBob
Hi Bogdan,
Requested files attached.
Note the problem appears related to shortcuts installed on the common desktop. The install is per machine. Most shortcuts are added to the common start menu as usual but 3 programs shortcuts are also added to the common desktop.
Bob
Hi!
It looks like it is a Windows problem.
It would be very useful for us if you would send us a link with the package that produce this error. We will continue to investigate the problem in order to find its source.
NBBob
Can I PM you download details?
Bob
You can send your download details to support at advancedinstaller dot com.
mheckmann
Has there been any solution to this?
thx
Markus
Hello Markus,
I'm afraid we couldn't find an exact solution for this, but you can try to change the Desktop shortcut name and see if the behavior persists. Also, you can try using "Build separate databases" option from the Mixed 32/64 wizard if you have a mixed 32/64 bit installation package.
stefanVoe
Same problem here!
Unfortunately, as my colleague Eusebiu mentioned in an earlier post, this is a Windows Installer problem and there's not much we can do about it. The only solutions we found were to use unique names for your shortcuts.
redseujac
I'm not sure what you mean exactly with "unique names". Can you explain a little bit more in detail and/or give an example, please.
I have the same problem with desktop shortcuts not being removed in Windows 8 64 bit system, while in Windows 7 I can't remember having run into this issue.
redseujac
Can somebody from the support team please read and answer my question in the previous post? Thanks beforehand for the effort ;)
I mean that you can use different names for all of your your shortcuts pointing to the same target file. For example if you have two shortcut (one on Desktop and one on Startup) for the same target file (e.g. MyFile), then you can try to use different shortcuts names (e.g. MyDesktopShortcut and MyStartupShortcut).
