cdburnett
Advanced Installer Features
I am looking for an installer that will be able to automate the installation of an ASP.NET website. I have read through the features of Advanced Installer on this site, but I wanted to make sure that it could do everything I need before I try it out. Can it do the following:
- allow user to select target drive/folder for installation
- copy all files from installation media to target drive/folder
- create new web site in IIS 7.5
- create an app pool and modify settings like Target Framework, Pipeline Mode and Recycling settings
- set specific folder level permissions on particular folders
- create a desktop icon and maybe even a Program Menu icon that is a shortcut to the site
- edit the HOSTS file (the application will run locally)
- edit the website bindings in IIS to use a specific host name
Thanks in advance,
Corey
Re: Advanced Installer Features
Hi Corey and welcome to our forums,
All of the below can be accomplished with Advanced Installer. I recommend you start with this simple tutorial to easily understand our application. Then you can continue with the IIS tutorial.
Folder permissions can be easily set from Files and Folders page.
If you have any questions let me know.
