talu3000
Custom window chrome
I'm wondering if it's possible to customize the window chrome of the installer. I'm using the Surface template.
I need to do the following:
1. Changing the black background color.
2. Changing the button template (specially removing the blue color arround it on mouseover).
3. Changing the height of the top bar. (circled in red).
Is it possible to do this?
Sebastien
Re: Custom window chrome
Hello Sebastien and welcome to Advanced Installer forums,
In order to achieve this you can change the "Background" image from "Themes -> Preview -> More Options" section.
For this you can change the button images from "Themes -> Images" tab. Please keep in mind that it is recommended to use images with the same size as our default images. Please take a look on our "Image Button" article.
You can change the images, from "Themes -> Images" tab, associated with "AI_CF_FrameCaption" and "AI_CF_FrameCaptionInactive" properties.
Also, you can take a look on our "Surface Theme Color" thread.
talu3000
Thank you for your help.
Sebastien
You're welcome. Glad to help.
talu3000
Do you think it's possible with this theme to add an Icone and a title on the top bar like standard windows?
Yes, you should be able to achieve this. For this, you can edit accordingly the images, from "Themes -> Images" tab, associated with "AI_CF_FrameCaption" and "AI_CF_FrameCaptionInactive" properties.
talu3000
Thanks that's exactly what I need.
