sally0108
Need to install drivers to system32 on both 32/64 installs
Ok - I'm pretty new to Adv Installer -- but I have an old VB6 application that requires some of the .dll and .ocx files to be in the windows/system32 directory -- even on 64 bit machines. VB6 has the directory structures hardcoded for these components.
so -- if I create package as a 32 bit -- the system directory is system32 when installing on a 32 bit machine -- but Syswow64 on a 64 bit machine.
What I believe I need to do is just install the libraries to both the System and System64 folders -- and on 64 bit machines it will be in both folders-- and on 32 bit machines it will be where it needs to be in the System32 fiolder.
can this be accomlished??
Thanks!
Re: Need to install drivers to system32 on both 32/64 instal
In order to achieve what you want you should use a "Mixed 32/64-bit matching the platform" package type and add the 32-bit files in "System" folder and the 64-bit files in "System 64" folder. Then, in "Organization" page you should use a condition like this:
NOT VersionNT64
for 32-bit files components, and a condition like this:
VersionNT64
for 64-bit files components.
Also, you can take a look on our "Folder Paths" and "Packages Types" articles which should be useful for you.
sally0108
under the "Install Parameters" tab - on the "Package type" drop down - I only have the options for:
32-bit package
64-bit package for x64 processors (AMD64,EM64T)
64-bit package for Intel64 (Itanium) processor
Please keep in mind that our "Mixed 32/64-bit installers" feature is available only in a "Professional" or higher project type. You can upgrade your current project type from "Home -> Options -> Project Type" tab.
sally0108
found it under "Project / Objects /Product Type "... thanks - never knew that was there!
You're welcome.
