sgturner
installing files after merge module install
Hi
I have an installer that contains some 3rd party merge modules. There are some files in the merge modules that I wish to replace with my own versions during install. How do I schedule the copy of these files so that they take place after the merge modules have been installed?. The default action seems to be that the merge module files are copied over mine.
thanks
steve
Re: installing files after merge module install
Hello Steve and welcome to Advanced Installer forums,
Thank you for yor interest in Advanced Installer.
In order to achieve what you want you can import the related merge module in your Advanced Installer project. Just open your project, go to "Home" tab an using the [Import] button select "MSI/MSM Package" option to import your MSM file. Then, you can go in "Files and Folders" page and remove the imported merge module file and add your current file.
Another approach would be to add you current file as a temporary file and, then develop your own custom action which will overwrite the file installed by the merge module with your current file added as a temporary file. Also, the custom action should be scheduled after "Install Execution Stage -> Add Resources" action group and should run as deferred with no impersonation.
