R.Mueller
Avoid installing wrong package with Mixed 32/64-Bit packages
how can I avoid, that the user installs the 32-Bit package of a mixed 32/64-bit package on a x64-bit system? He needs just to execute the msi package directly, instead of setup.exe.
I tried to use AI_PACKAGE_TYPE as Launch Condition, unfortunately this is set to the undocumented AI_ALL value instead of "Intel" or "x64". Is there a chance to reuse the AI_ProgramFiles and compare it with ProgramFilesFolder or something like this?
RM
Re: Avoid installing wrong package with Mixed 32/64-Bit pack
Unfortunately, there is no property that detects the type of a package.
Also, you can achieve what you want by following the steps below:
- we assume that your application uses the default Application Folder in the Install Parameters page ([AI_ProgramFiles][Manufacturer]\[ProductName] is used for a mixed package type)
- in the same page create a new property (i.e. MY_PATH)
- go in the Custom Actions page and create a "Set installer property" custom action, place it under the "Wizard Dialogs Stage" -> "Paths Resolution" action group and use the following settings:
  • Property: MY_PATH
    Formatted: [ProgramFilesFolder][Manufacturer]\[ProductName]\
- create a "Display error message" custom action, place it under the "Set installer property" custom action created earlier and use the following settings:
  • Message: This is a 32-bit package
    Condition: APPDIR = MY_PATH
- build and run the project
R.Mueller
Hi Eusebiu,
well, when I do so, its completely blocking the installation.
My scenario is the following: I have a installer using combined 32/64 packaging mode. That means, I get a 32-Bit msi, 64-Bit msi and setup.exe and a common cab file for installation. Currently its possible, that the end user on a 64-Bit system is able to start the 32-Bit msi file directly and therefore able to install our software in 32-Bit mode. This is not supported by us and therefore it should be avoided.
Question is, how to achieve that. I need a property or similar, which tells me, this is the 32-Bit msi, then can I test, if its currently running on a 64-bit system and avoid that.
Roland
R.Mueller
Hi Eusebiu,
uuuh, after some MSI log file reading, I found a solution, which works based on the knowlegde how AI is producing the mixed packages. I already mentioned, that we use the mixed package type. When you do so, you will get a TheClient.msi, TheClient.x64.msi, TheClient.cab and setup.exe. Setup.exe is responsible for taking the right msi package.
I found the property OriginalDatabase which contains the msi package name (hence its called "Original..." I asume, that this property is based on the package name during creation of the installer). Now you just need to test, if the msi package name contains a x64 for being designed for x64:
Create a new Launch Condition, add as condition
OriginalDatabase ~>< "x64" and VersionNT64
and as Description
Please use the 64-Bit package for installations on a 64-Bit system!
and rebuild. When I start the packages directly, it shows me the message in case of the 32-Bit package on x64. The other case (installing x64 on x32) is blocked by MSI by default.
Is this a reliable solution for my problem?
Roland
Hi Roland,
I tested your scenario, but it looks like the installation of a 32-bit package is also blocked on a 32-bit system.
Indeed, my scenario behaves the same because I forgot to mention the right condition for the "Display error message" custom action, which is APPDIR = MY_PATH AND VersionNT64 instead of APPDIR = MY_PATH.
I attached a sample project, so you can take a look on it and also build and run it to see how it behaves.
Let us know if this helped.
Mixed 64-32 bit.aip
(17.29 KiB) Downloaded 516 times
