sudheerkosuru
Error while runnig setup after mysql has been added
Hi
I need to bundle my web application using Advance Installer for Tomcat Web Application features. Am using the 9.9 trial version, I would purchase the license if bundling process has been completed without any trouble..
Below are details of my web application,
JRE 6
Tomcat 7.X
MySQL 5.X and
my application WAR file
I was trying the step by step of including jre and tomcat then mysql,i was able install and run till tomcat.But after adding mysql to prerequiste i'm facing problem.
While running setup file mysql was installed properly,but application is failing by throwing "error couldnot access network location 3306]https://www.dropbox.com/s/60iiim7t8odwv ... 4%20PM.png
Kindly suggest how to inlcude mysql along with tomcat and script file with tables to be imported to mysql,and launch application.
Thanks in advance
Sudheer
Re: Error while runnig setup after mysql has been added
This may happen if one of your application folders paths are resolved to an invalid path during CostFinalize standard action. Please keep in mind that your application folders paths should be resolved to valid paths on target machine. Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
sudheerkosuru
Hi Daniel
Thanks for your reply,
Attached is my setup file(.aip)
i was trying to create log file but it is thorowing error while creating location no specifed,i will try with log and update again,meanwhile would be help full if you could check with aip file.
Thanks inadvance
Sudheer K
Hello Sudheer,
This happens because your property-based folder (PORT_PROP) location it is resolved to "3306" (its associated property value). As I mentioned in my previous post, you should be aware that your application folders paths (from "Files and Folders" page) should be resolved to valid paths on target machine. However, in order to avoid this issue you should set valid paths for your properties (i.e. DATABASE_PROP, PASSWORD_PROP, PORT_PROP, SERVER_PROP, USERNAME_PROP) defined in "Install Parameters" page. For example you can use a value like this:
C:\Program Files\webapps\3306
for your PORT_PROP property. So, can you edit the related property (used to create property-based folders) accordingly and see if the behavior still persist?
sudheerkosuru
Thanks for your time and reply Daniel
Actually i misplaced the dialog setting properties in user defined rather than user interface,Now resolved the issue and able to successfully create a whole web application package.Now trying if we can create dialog with user input to hold along with application.
Thanks to Entire team of Advance installer for making my job done a lot quicker and easier.
Regards
Sudheer Kosuru
