eric
installation english languange
Hello everybody,
is there any way to install advanced with english (using 10.0).
I tried of course, but it hasn't shown me an offer, to chose a languange.
I have a Errormessage, and I like it better to post it here in english.
Thanks, Eric
Re: installation english languange
Hi Eric,
AI's installation language is automatically set to English because this is the only language included in its installation package.
If you want to change the default language of your projects you can set it in the Start page, "Options" section. Also, you can go in Translations page and select more languages for your project. If you want to let the user choose installation language at install time you can enable the "Display language selection dialog (for multi-language packages)" radio button.
If the above information doesn't help, can you please give us more details about your problem?
eric
Hi Eusebiu,
sorry I can not agree that.
What is it what you call "Start page"?
"Option" ist only inside of "Home"
best regards
Hi Eric,
Please keep in mind that the AI's language and the project language that you create with Advanced Installer are not the same. The AI's language is always English. The project language is usually set to the Operating System's language and you can change it in the Start page. I attached here a screenshot with the Start page.
eric
could change it, but the errormessage is still comming with those languange which system has
(as you told maybe)
Can you please go in the Translations page of your project, select only the English language and see if the behavior persists?
eric
you just gave me a new reason to stop here, and carry about inno-setup or wixinstaller or whatever.
Almost a half has passd since I try to figure out some basics.
Maybe I should have used that time for other stuff..
And beside, the most reason for that is seeable in your last answer.
"Translation page"
Why its hard or forbidden or ... have no idea, to give a description like that A->B-> C->
Hi Eric,
I'm sorry, I don't understand what wasn't clear in the steps Eusebiu mentioned in the last post. The "Translations" page is available in the left menu of
Advanced Installer, when you open your project. There you can select the languages desired for your package.
From that page, Languages tab, you can also enable the options "Display language selection dialog", that will give you a small dialog from where you can select the language desired to install the package,
when the setup is launched by the user.
eric
perhaps we can talk about that with email?
Just an offer, I will keep going here as well.
You can send your e-mail to support at advancedinstaller dot com.
eric
You bellive hardly (it seem so), your handlings are on top, there nothing which could be better.
In that case, .. dictaturs has fallen, mostly because they have only listen to those, who talkd nicly to them.
All fine guys, lets go
Sorry, but I don't understand very well the idea in your last post. Can you please explain us a little more in details?
eric
Bogdan came suddenly over that, has seemed he wanted find out whats wrong.
So I offerd email-contact, but then that support email was given.
Sounds not like intrest in.
Well then, dont let us waste time.
