Shania
How to install a driver depending on the feature.
Hello! Help me please.
Why my driver is always install? While the INF file is in feature, which I did not install.
How to install my driver only together with a feature? Otherwise do not install.
Thanks.
Re: How to install a driver depending on the feature.
Thank you for joining Advanced Installer forum.
Once you add a file to the project, Advanced Installer will create for you a feature. You can go in the Organization page to see the feature that contains your .inf file. If that feature will not be installed all the files contained by it won't be installed at all.
If you still have this issue please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them.
Shania
Thank you very much.
I am doing as you write, but if the feature1 selected "Not installed by default" - does not install the driver never. Even if the feature1 is enabled when you install msi.
Vice Versa. if the feature1 selected "Installed by default" - my driver is always install. Even if the feature1 is disabled when you install msi.
feature1
feature1
drivers
drivers
In the Installation Settings, the default value is: "Install the feature locally" not: "Run feature from installation source". Try this option and if you still have have an issue use the option " Use parent feature installation settings". If the problem still exists, please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them.
Shania
Thank you very much, Dan.
The option " Use parent feature installation settings" + the option "Always install this feature." gave the desired result. :D
Although it seems to me that it's not very logical.
You're welcome.
