Skylla
Use custom action to determine if chained pkg is installed
Hello
I would like to use a custom action to determine if a chained pkg should be installed or not.
I would do this by setting a property that is used as a condition for installing the chained package.
Is this possible?
Where in the InstallExecuteSequence do I run the custom action?
Skylla
Re: Use custom action to determine if chained pkg is install
I've got this to work following the approach described above.
Except for one thing.
I'v have a problem in the following scenario.
Package A chains package B
Package B runs a custom action to determine if package C should be chained
In other words:
A chains B, B may chain C
If i install A, B gets installed, but C doesn't even though the custom action runs.
If I install B directly, C does get installed
I can see in the log that the custom action do set the property used to control the chaining of C in both cases (INSTALL_C=1)
I'm not sure why this happens. Can you please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
