As part of the installation we would like to create a SQL Server database using SQL scripts. I currently have the following on the SQL Scripts page in Advanced Installer.
CustomConnection
Condition: CHECKBOX_DATABASE
Connection Type: Microsoft SQL Server / MSDE
Connection string: Data Source=[DB_SERVERNAME];User ID=sa;Password=[DB_SAPASSWORD]
Login timeout (sec): 60
Connection and all its scripts are verbose: Checked
Transaction
Script_File
Run SQL: at install
On error: Abort installation
There is also a SQL Script Replace.
I have built the installation and tried to run it on a test machine which resulted in the following error.
[SQLDriverConnect] {SQL_STATE: IM002}
[Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
[OK]
As a result I have the following questions.
1. Does the SQL Scripts portion of Advanced Installer require an ODBC connection?
2. Is there a way to utilize the SQL Scripts portion of Advanced Installer with a different connection method (ADO DSN-less, OleDb, etc)
Your help is greatly appreciated!
