digitalrinaldo
Unable to recognize the java version 6-29 installed on the w
Steps:
1- Access the link - https://devint-client.redplum.com/Apple ... Offer.html
2- From Print a test page and go to a new page section - Click on Link Installed Print Test Page
3- Browser will ask you to install latest Java 7 update 25 even though Java 6 update 29 is installed on the system
4- Click on Allow to install latest java version
We have generated a 32 bit executable and have the following settings for Java Detection
JRE is a prerequisite
Does the Java Check only look in the 64 bit location
Settings 1
Settings 1
Screen Shot 2013-07-24 at 6.04.11 AM.png (32.84 KiB) Viewed 6841 times
Settings 2
Settings 2
Screen Shot 2013-07-24 at 6.06.07 AM.png (36.25 KiB) Viewed 6841 times
digitalrinaldo
Re: Unable to recognize the java version 6-29 installed on t
I have specified that the minimum version is 1.7 in other screens -- why is the registry entry still saying 1.6 see attachment.
Registry key is set to 1.6 when it should be 1.7
Screen Shot 2013-07-24 at 10.55.10 AM.png (114.31 KiB) Viewed 6832 times
Please keep in mind that the JRE Version specified in the "Java Virtual Machine" tab is not related with the JRE version detection criteria specified in the "Prerequisites Install Conditions" tab of our JRE predefined prerequisite package. If you need you can edit the minimum version of JRE prerequisite from the "Edit Search" dialog.
Also, please keep in mind that by default the prerequisite install conditions are evaluated using 32-bit locations on a 64-bit machine. However, if you want your prerequisite installation conditions to be evaluated using 64-bit locations you should check "Use 64-bit locations when evaluating conditions on a 64-bit machine" option from "Install Conditions" tab.
digitalrinaldo
Using the config above the following user experience was observed.
  • User launches the Installer built with AdvancedInstaller
    Executable launches and says there is no Java user is given a UI showing that
    Java is installed and at the end of the installation we get an error message.
The java Install was for 32 bits -- so is the prereq saying check 64 bits not being satisfied.
Screen Shot 2013-07-30 at 11.30.18 AM.png (37.96 KiB) Viewed 6783 times
This happens if the prerequisite install conditions are not fulfilled after the prerequisite package is installed. Can you please make sure you are using valid prerequisite install conditions searches and check if they are fulfilled on target machine after the prerequisite package is installed?
digitalrinaldo
Thanks for your patience. What we are slowly understanding is that we don't understand how to configure the application we install to accept either a 64 bit or 32 bit JRE or JDK.
We install a 32 bit application on a 64 bit machine. We use the default values and have turned off use 64 bit locations and in this case a previously installed 64 bit application is not accepted as meeting the prerequisite. Do I have to add another registry entry for the 64bit JRE locations?
I'm afraid I don't fully understand your scenario. Can you please give us more details about this (maybe exemplify)? Also, can you please send us the .aip (project file) to support at advancedinstaller dot com so we can investigate it?
