Sorry if this is a simple question -- I searched and could not find the answer.
I have inherited a project that is distributed using Advanced Installer.
When being installed on Windows 8 computers, I get the error message, "Windows Protected Your PC" and an OK button, which prevents the file from being installed.
If I click on the tiny, "More Info" link, I get "Unknown Publisher" but an option to run anyway.
On earlier versions of Windows using IE (works in Firefox & Chrome), I might get a dire warning that running this file may harm your computer.
Is there something I can set in Advanced Installer to allow our product to be installed on Windows 8 without this error message, and also to be installed on earlier versions of Windows after downloading from IE without the message that it might harm your computer?
Thanks in advance.
